Nice picts. Just one tought from my side.
If the car was mine, I whould replace the reinforcement rails. They are heavy metal rails with on the inside a V shaped profile ( v with a flat bottom. They are needed to avoid that once you step in to the car, the doors whould shut and open normaly. I had checked an early convertible for a friend a few months ago. With pict album from the resto.... Guess what, they did not use the original reinforcement rails but aftermarket...when I pointed them to this issue, they told me...they are ok. Then we steped in to the car with 2 adults (95 kg each) and the doors jammed terrible. The Z plate inside the heater channel and the V profile was not copied in the aftermarked rails.
I am sure you can weld them up but will they be ok? and what about warping due to welding.
My 1303( sorry rob:omg: ) was once welded on one side.Well done but due to the tension...The doorgap is not ok now. I know it is hard work but then you can be sure that all the work is ok. Just my idea. :thumbup:
