The PO of my '61 US spec Beetle apparently had an issue with the original wiper switch, so he(I assume) wired in some funky switch so he could control the wipers 'parking' I removed the switch and set the wiring back to stock and then discovered the problem. The wipers continue to run even after switching them off with the stock switch. I have an SWF unit, 6v(will be converted to 12v) and have removed the entire assembly from the car. Any guidance from someone that has been through this before will be greatly appreciated. Thank you all
dws
BavarianRescue wrote:
