lutty
  • lutty
I have a 54 oval with an original 30hp engine, I would like to have a bit more power, I have seen that wolfburg west make a repro okrasa kit for 1395$. Has anyone got one of these kits & are they any good or should I go for a judson
thank you for your help
The kit has quality issues. Mine came as standard with 3 leaky valves and badly cast heads that lack adequate seating surfaces. The manifolds are none too clever either I am told. Unless you are a bit handy with welding ally and are generally a demon engine builder, then I´d pass until they get their quality control sorted out. A simple "bolt on" it isn´t.
i had 4 kit's in my hands and only 2 heads had problems with the valvguides...
for the price you would not find anything better. my heads are running since 4500km, and 2 other engines (only bolt on okrasa) runn also great... the only thing is that i would check all before and i recommend to check the carbs carfully
i had installed a judson years before.... and i would never do this again... :shock: :wink:
How many of the heads had the seating problem? ( I know it´s not always a problem :wink: )
What was wrong with the carbs?
Oh I meant to ask you - how much did it cost to get your wheels re-chromed?
no seat was leaking, but 2 valveguides hav not been on the end...
i head was machined not right in the center....
the carbs are okay, if you clean them...some have casting rests on some holes...
the rechromeing is a special price i got of a frind of mine....
Ah thanks Andi. Nothing too serious then.
Shame for me about the chrome.
