Upgraded to Photoucket Pro as I'd exceeded my bandwidth and...... we're back in the room!
So, moving swiftly on.....
Firstly, before I start with today's discovery, I've realised that my new hobby of collecting NOS Oval parts is not the least expensive one I could have chosen, but fun never the less.
My latest addition to the Oval will be a nice NOS set of points.
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC03381.jpg)
Anyway - back to the compression issues. First job was to either prove or discount the option of gummed up rings, so I bought a bottle of UCL (Redex, here in the UK)... and then tried to figure a way of getting it into the cylinders without making a mess. I thought the drinking straw on the end of a syringe was a neat idea?
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC03392.jpg)
I'm not a Gynaecologist, but I'll take a good look at it for you!
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC03394.jpg)
After a good crank, I did another compression test, which made no difference to the three that were void, but there was a little more on the 'good' cylinder.... Nothing to have a party over, but a step in the right direction
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC03403.jpg)
Next job was to pull the rocker cover off - came off quite easily to be honest and I was quite surprised at how clean everything was in there - thought it might be a lot more gunky.
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC03408.jpg)
And here is the offending valve gear...
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC03407.jpg)
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC03406.jpg)
GOOD NEWS - At least I know what the problem is now. I slowly cranked the engine by hand whilst watching the rocker gear move, which is awkward to say the least and requires long arms, but very soon the problem became obvious. The exhaust valves are stuck open.
Simple as that.
So, as it'll do no harm, I absolutely drenched the exhaust valve springs in plusgas penetrating oil in the hope that a little might make it down the valve stem. Maybe it will, maybe it won't. We'll see.
I'll give this a couple of days worth of application and see if anything frees off a touch, and if not, then I'll have a look at pulling the rocker gear and off and seeing if there is a way to gently push, pull, twist or shock the valve a touch to free it off.
I have to say that I'm relieved that I've at least found the problem.
