Between looking after the kids, watching the Formula 1 and having dinner, I managed a couple of hours in the garage.
Firstly, I wanted to make a bit more progress up front so I thoroughly degreased the frame head and bottom plate then gave it the first of two coats of black waxoyl underseal. It is the only concession I'll make in terms of 'colouring' anything, firstly because it is a little more hard wearing than the standard waxoyl, and secondly because it will come straight off with white spirit in the future should I wish to detail further or re-apply, but I know it will give excellent protection.
I also fitted the NOS master cylinder after cleaning and copper slipping all the mating faces, nuts and bolts etc. Once all the hard lines are attached, I'll coat it in clear waxoyl to prevent surface oxidization.
I then tried my next idea on the stuck exhaust valves. Firstly I removed the push rod (perfectly straight for the record) and then taped together a stack of coins to act as back stop for the rocker arm to push against.
The idea is that I used the power of the adjusting screw on the rocker arm to force the valve open as I screwed it in, which is a far more controlled way than hitting it with a hammer - well, it is with my hand to eye coordination anwyay...
I set up the taped stack of coins over the empty push rod hole so with the adjustment screw wound all the way out there was hardly any clearance to make sure I got the maximum amount of push from the screw.
I then carefully screwed the adjuster in until it was at it's maximum travel. It turned in with a mild amount of effort all the way until the end - which was a big relief, as at least I know the valve(s) aren't seized solid. With it fully depressed, I soaked it in plusgas again, just in case, then wound it out again - then in again, out again, in again, out again etc - about a dozen times.
This picture shows how depressed I managed to push the valve.
At this point I removed the rocker arms to assess the valve position in the hope that it was now further out and level with the inlet valve.
It was not.
I tried to push it in with my thumb as I can just about manage with the inlet valve, but I couldn't.
Did a quick compression test to see if I'd made any difference whatsoever, but it still didn't read.
So - in conclusion from today's experiment - the valves move, they are not seized solid, but are perhaps a little stiffer than normal (not a big shock) but more importantly, they as of yet are not seating correctly enough to give any compression.
I'll sleep on this and pray for the midnight fairies to come and sort it out, but without any compression at all, there's no point even trying to fire it up in the hope that it will free itself up, as the empty cylinders simply won't fire. I'd try this if there was a little compression, but with none, I think I'd be wasting my time.
I can see what's ahead, and if that's the ONLY way forwards, and there are no further bright ideas, then so be it - it'll be fun.....?
:lol:
