Well, the post man has finally arrived, and boy was it worth waiting for as all sorts of NOS goodness awaited me when I got home from work!
First up, what we've all be waiting for - the NOS front transmission mount!
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC05914.jpg)
Which surprise, surprise, fits like a glove with no twist. Lesson learned! I made sure to clean up the areas where the earth strap mounts for a good contact, then once assembled, re-coated with sealing wax.
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC05923.jpg)
At this point, I'd like to mention the fabulous service I received from 'House of Ghia' who supplied the mount. I told them it had not turned up when it was late and Mike immediately apologised and set off to find and secure me another one, which he did, and then offered to send it to me free of charge! What a star! The first one turned up the day he was due to post it so we saved it just in time - thanks Mike.
Ant what other goodies arrived...?
How's about a NOS steering coupling?
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC05915.jpg)
I was not sleeping well with the fact that I'd fitted a rerpo cable conduit rubber boot a few weeks ago, so when the chance arrived, I grabbed it - NOS!!!
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC05916.jpg)
And my favourite bit so far....? This beautiful NOS screw terminal brake light switch.
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC05917.jpg)
Which would not be at home without it's little friend, the screw terminal oil pressure switch.
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC05919.jpg)
Finally, a nice stash of SG profile key blanks for when I get my new ignition switch and other locks all matched up for the one key.
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC05918.jpg)
Anyway - enough present opening, time for some action! If you recall, the transmission kind of came out in a bit of a hurry and no pictures were taken of the removal, so for those that want to know, this is a step by step guide of how to remove / install a VW transmission. In this picture sequence, we are fitting it, to remove it, do everything in reverse!
With the new mount and earth strap fitted, I lifted the box of the engine stand and rested it on my new high lift jack.
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC05929.jpg)
This jack as a low entry point and is typical of much smaller jacks with an entry height of approx 125mm or 5". I calculated that to get the transmission under the rear valance whilst resting on the jack, a floor to valance clearance of approx 200mm or 20" is required. To lift the rear of the car this high I used my new monster axle stand which lift plenty high enough.
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC05930.jpg)
Once you have wheeled the trans far enough forward to put the bell housing roughly in the middle of the engine bay, raise the trans up to it's correct height and roll it forward a little so it is about 8" rear of where it will end up. At this point you need to engage the bowden tube for the clutch cable in the support bracket on top of the transmission casing. You will not be able to do this if you bolt the trans in position first!
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC05946.jpg)
Notice the new rubber boot on the end of the tube to keep moisture and dirt out of the cable conduit...
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC05945.jpg)
This is a good time to fit the rear cross member and engine mounts. I used new genuine VW items which were very nice quality. To make sure there is no undue stress put on the mounts, it is recommended that the mounts are tightened to the bell housing case first, then once the front mount is tightened, then tighten the mounts to the cross member, then finally the cross member to the frame.
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC05932.jpg)
Once the mounts are in position and the bowden tube is located correctly, slowly and gently push the transmission forwards keeping the selector shaft at the end of the nose cone lined up with the entry hole in between the frame forks. If should slide 'home' with little effort at all - if you end up having to man handle it, stop - something is not right - go back and make sure nothing is getting fouled up.
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC05939.jpg)
Making sure the transmission is still level, you can now secure the front mount using the two outer mounting nuts.
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC05944.jpg)
And as stated earlier, the rear cross member can be bolted to the frame horns. The transmission is now supported and secure so the jack can now be removed. And there it is, back in it's rightful home once again!
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC05951.jpg)
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC05950.jpg)
With the transmission back in place, I next connected up the gear linkage rod using the original coupler and square headed bolts. These have a hole in them to allow the fitment of some security wire to prevent them coming undone. The 'orange' in the picture is a combination of copper grease and amber sealing wax!
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC05934.jpg)
Next up I replaced the wiring loom to the started motor solenoid, again making sure to clean the terminals for good contact before re-sealing them with wax.
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC05937.jpg)
Then it was time to refit the two nuts to the end of the clutch cable - these will be set up and adjusted properly when the motor is back in.
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC05947.jpg)
And last but not least, after giving them a quick clean up, but not over the top, I refitted the spring plates to the ends of the axle tubes.
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC05953.jpg)
In my next update, I hope to be showing some progress with the hubs and brakes etc.
That's all for now folks!
