Great. was thinking about this after I had posted and realised that you will also need to adapt the metal fuel feed and vacuum pipes. The usual mod is to cut the pipe and then fit a section of flexi hose between it and the carb.
It seems a shame to cut an original pipe, but if you have a supply you'll probably not worry to much. Otherwise you can buy repro items from several suppliers (for the fuel pipe at least) so you might want to get one of those and cut that.
Hope that helps
Mike Peckham wrote:
