Rob, can you move this to the Rattletrap thread please? :roll:
There was one chassis change documented and this happened after the car was registered by Tony in the Ancient Beetles Register, making the number he quoted the original. In any case, the replacement chassis was a post ‘08/55 type. The chassis number quoted by Tony as the cars original refers to a Jan ’53 Zwitter, (Black with a red interior) so clearly not that of the later chassis.
I understand from what you say that the car has had an earlier chassis fitted between the rebuild and your buying it, if this is the case, any number on there, whether it be legible or not, will bare no significance to the build date of the original car.
Considering the extent of the damage to the car and the amount of replacement panels used in its rebuild, I would not trust that the front clip is the original so any body number on there should be treated with caution.
As you have said, and rightly so, anyone claiming their car to be anything other than what it appears should get hard evidence from Volkswagen themselves to prove their case. Your car appears to be a 1953 Zwitter, the chassis number confirms this.
In order to prove that it is not what it appears, you will need to get hard evidence from Volkswagen that they produced a run of prototypes in 1950 that were exactly the same as the short run of zwitters produced 3 years later and that they issued these cars with chassis numbers that would indicate they were made 3 years later.
Do that and you might have a case.
Mike :thumbup:
Mike Peckham wrote:
