Whilst I'm building up to the big day, I'm now tacking all the silly fiddly jobs that might hinder progress on the day.
I needed to fit the flexi fuel hose to the rear and did so with the stainless clips again... well, because I had them so why not. Note the new rubber grommet where the solid line exits the frame horn.
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC06565.jpg)
And where it joins the solid line that enters the engine bay through the rear tin shroud.
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC06573.jpg)
I thought it best to fill the transmission with oil before I forgot...!
It takes 2 litres for an oil change, or 2.5 litres from completely empty after a strip down of the axles etc.
There wasn't much space for the funnel, or indeed to empty the container of oil into the container. It felt a bit like trying to take a pee into the toilet from the hallway with your hands tied behind your back without getting any on the carpet...
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC06563.jpg)
I thought it might help things along a little on Wednesday if it actually had a battery, as I didn't want my lawn mower getting jealous watching me try to pull start it with a length of rope round the pulley.
Only a correct rubber cased original 404 battery would do...
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC06575.jpg)
It had been a while since I'd snorted a line of NOS, so I went for a rummage in the holy box of musty smells which rather conveniently surrendered a nice NOS battery cover.... don't you love it when that happens?
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC06579.jpg)
Nice perfect tight fit!
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC06581.jpg)
The rear of the floor pan and battery tray was caked in about an inch of farm dust and before I fitted the battery thought it best to give it a good vacuum, stiff brush and then soaking in the protective sealing wax.
Like everywhere else, other than a little surface rust which pretty much wiped off with a soft brass brush, it's solid as a rock - same sort of condition as the inner wings. It looks dark and shiny in this picture because of all the wax that was still wet when I took the picture.
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC06578.jpg)
As the car will spend extended times in storage through the winter months and general infrequent use, I thought it prudent to invest in a 6V charger / cycler / conditioner which I have left attached to make sure we have healthy cranking ability should it refuse to fire up quickly.
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC06586.jpg)
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC06588.jpg)
And finally.... This is where I'm up to with the battery strap...
![UserPostedImage](https://i83.photobucket.com/albums/j301/last_triumph/Oval/DSC06584.jpg)
Anyone got a picture, dimensions or even better, a spare clasp I might acquire to fill the missing link between the strap and the flange hook?
Not long now boys and girls....
