I finally got hold of the correct OEM ATE master cylinder plug which allowed me to finish the installation of the brakes.
I then refilled the system and bled the brakes a couple of times.... but the pedal was going almost all the way to the floor like I was pumping up a tyre....
Hmm - something's not right.
I bled them again to make sure there wasn't any air in them and tried again - still the same problem. It was going to be one of those nights I could tell...
I checked all round for leaks and to make sure all the union nuts were tight etc, then bled them like there was a tax rebate at the blood donor centre.
Again, no improvement.
Then it dawned on me - I'd not adjusted the shoes !!!!
If I was my own twin brother, I'd have kneed me in the nuts...
A quick adjustment saw the problem solved and pedal nice and firm, which was a big relief. I was then able to top the system off with a new rubber resevoir cap.
With the brakes done, I cold now close up the front end with the fuel tank that I'd cleaned and sealed what seems like such a long time ago.
I bought a genuine new VW fuel tap and fitted it to the bottom of the tank.
Here's a shot I managed to get of the inside of the tank with the filter gauze showing.
I then fitted ta new rubber grommet to the solid fuel line where it comes out of the frame head.
At this point I'll mention the fuel hose. Some of you may or may not know but modern fuels contain all kinds of additives and cleansers which very quickly rots traditional rubber fuel hose in as little as a few months in some cases and many fires are a result of this normal rubber hose failing.
To this end, I managed to find some NBR nitrile hose which not only is chemically resiliant to modern fuels, but in this case also comes covered in a lovely black cloth braid so it looks identical to what was fitted at the factory - it even has the correct 5.5mm internal diameter to ensure a snug press fit over the solid fuel lines.
If anyone wants any, I had to buy a huge reel so am willing to sell the rest to recoup my expense. Anyway - it's great stuff!
Despite it being 5.5mm diameter and a nice snug fit, where fuel is concerned I'm happy to go belt and braces, so bought some nice stainless hose clamps with anti pinch devices.
I bought a new correct gasket for the tank which was a perfect fit...
Four bolts later and hey presto - the tank is back in!
I even used the original split pin that secures the fuel tap to the opperating lever!
And there it is - all back the way it should be, complete with original tool roll, tank dip stick, jack and spare dynamo belt on the spare wheel!
Getting real close now!
On a separate note - I discovered amongst my treasure, a NOS mirror which I'd like to fit to the door hinge, but I'm not sure if I have the correct hardware or hinge pin etc.
Can any of you experts tell me what's wrong here and how I get this mirror to fit?
This is what I have..
Thanks.
